awesome, hell I can make him make me one at work....meminto wrote:I can confirm that it is a stud...
Totally serious. Don't kill him, just take away his tool privileges for a whileca18detgabby wrote:your serious!!!! it screws in and out!!!!!!!!!!
holy crap I hope you are serious.
you have no idea, but he nearly hit the sealing he jumped so high when he read that.
so there isnt an adhesive?themadscientist wrote:aluminum head vs steel stud, you should be fine. It has been in there for 2 decades though so expect a fight.
about to do the same thing to my bfs teeth.ganma_ca wrote:Then ya do the hokey pokey and the stud falls out? That's what it's all about!
its a wonder you dont have any luck with women........themadscientist wrote:Gabby, I know you need advice on how to be a typical girl because you are a pretty cool chick, not an evil ***** like most women. The trick is to stick this somewhere in the corner of your memory and whip it out in the middle of a completely unrelated argument years later.
Him, you used my favorite shirt as a rag? You, it was full of holes and dirtier than the other rags. Him, I can't beleive you did that! You, remember that stud you broke in 09'? Him, what? WTF does that have to do with this, huh?
And while he stands there trying to even remember you keep polishing your wheels with his shirt.
Yeah... just a littlethemadscientist wrote:The double nut trick is the way I pull every stud, always works.
Did anybody else get a gay vibe from that sentence?
i tried that........ to say it was not successful...... is an understatement.zero_gripS13 wrote:rare trick is no more .
for vac line just snip a lil section of the hose u want and goto autozone or ur choice and ask for several feet of each sample then goto town... before my motor goes in the intake manis going to AZ and im replacing every hose ill be cutting up radiator hoses and **** tillits alld one since ill never find replacements for them..then ill just keep track of all the part numbers for future needs
If you can give me an idea of what size...... I can order pretty onesr34 gtr wrote:You want Good Year fuel & emission hose, they carry it at the AZ. Go get you some 1/4"and 3/8". I'm not 100% on the sizes but I will check for you when I get home at 3:30 today.
yeah but i think that the vibe u like and wanted to give off anywaythemadscientist wrote:The double nut trick is the way I pull every stud, always works.
but yeah i know that trick, i used it to reuse the stud from the water pump since the replacement ones were not correct...workspretty well
i would suggest socking the SOB with PB blaster if u can and then go at it...
GL gabby
yeah I have a few more vac lines.......r34 gtr wrote:I forgot you probably have 20 more vacuum lines than me.
1/4" for the wastegate and BOV and whatnot
3/16" or 1/8" (1/8 seems like it might be too small) for the FPR, MAP sensor, and boost gauge.
