Tension Rods with Pillow-Ball Ends
poems2beats
Car: Nissan S13 pignose-sold
Nissan S14, current project
99 Honda Civic, current DD
Not to long ago (like in Nov.) I installed some wicked tuning tension rods, but just recently my steering wheel has been jerking to the side wenever I go over a bump. But not just a normal jerk, it jerks to the side pretty hard. Now im wondering, is it suppose to jerk this hard? Someone please enlighten me im starting to get concerned....
I do realize i used the word jerk alot .lol.
naed240sx
Car: .....
Did you get an alignment afterwards? You probably didn't set them to the same length as the stock ones and caused a toe out condition.
poems2beats
actully I did get an alignment.
naed240sx
Car: .....
Is this the only thing that you installed? Or was this one of several parts that went on before this problem ocurred?
What front alignment specs did you get (camber/castor/toe)? Are you running coilovers?
I mean my car jerks around a bit going over bumps, but that is to be expected with stiff suspension unless you have your bumpsteer set to exactly zero, which is unlikely
gumby74
You may want to pop your head in there and make sure everything is still connected and in good working order.Then check you tie rods and ends.
CMG
Car: 1989 240sx Hatch w/ Redtop
Check out your suspension, tires, steering rack etc. Could be any number of things from tire wear, bushings, control arms, etc.
poems2beats
lol. Im not some crazy hardcore drifter. I just got a regular aligment, the kind normal ppl get. I also installed OEM control arms and tie rods.... Coilovers pshhh, I wish....
CMG
Does it pull to just one side, or both sides depending on bump. Could just be bump steer, is your car low?
naed240sx
Car: .....
poems2beats wrote:lol. Im not some crazy hardcore drifter. I just got a regular aligment, the kind normal ppl get. I also installed OEM control arms and tie rods.... Coilovers pshhh, I wish....
why the hell did you get new tension rods with heim joints if you weren't planning on running different alignment specs that stock?
poems2beats
CMG wrote:Does it pull to just one side, or both sides depending on bump. Could just be bump steer, is your car low?
Naw, i have the stock shocks and springs.
naed240sx, i found the wicked tuning parts for about the same as OEM replacements. So I said "wat the hell, Y not get these". Plus wen my car is in good shape and i have money, I do plan to drift.
