car nut »
https://forums.nicoclub.com/car-nut-u145197.html
Sun Oct 17, 2010 10:32 pm
I would recommend aftermarket if you ever plan on doing anything with your suspension in the future (and you have the cash). Aftermarket arms are adjustable and lighter than factory tension rods, but besides that they hold no advantages. Also, considering you can grab a set of used OEM tension rods for pennies on the dollar, they're a lot cheaper than a set from say Powertrix ($139 last I checked).
As far as getting them installed, why do it at a dealer? There's literally 3 bolts on each rod, 2 14mm and one 17mm. That's it. If you're getting adjustable rods you'll also want some antiseize, and lithium grease but other then that you're good.
