Tension rods
IanS13
Installed tension rods today after haveing to cut the old ones off with a saw but that's a next story, well I got these revo tension roda and they work great no more shaking steering wheel, but the steering still feels a little lose what can i do to might it feel tight.
Nismo_Freak
Car: 89 Nissan 240SX
Replace tie-rods and get an alignment to make sure the caster is set correctly.
IanS13
tie rods are brand new.
chmercer
what do you mean it feels loose? do you mean you have a lot of steering lash? your rack might be worn out..an idea
Red coupe
Car: 92 Nissan 240sx Coupe
yup but if its not actually to much play, the steering is just lighter then it was before Then your caster might be off, Did you get an alignment after you put them on?
SmithSR
Car: 240sx
Don't forget to check rack bushings.. Phase2 sells nismo units and they are a viable upgrade over old worn oem bushes
IanS13
not i did not get it aligned but it will be soon, i think i might do bushings, i theering feels lose kinda like my bro caddy. but not as bad but still i want to stiffen it up make it more responsive.
