shaginator »
https://forums.nicoclub.com/shaginator-u3941.html
Wed Jan 22, 2003 4:43 pm
From what I've been told -- yes. Also, if you see cracks in the rubber part of the bushing, that's more than a good time to replace them.
One thing -- if you only see cracks, but no silicone that may not mean it hasn't leaked, but rather, all the silicone has leaked out already...
What I've noticed on our Q (non-active suspension) is that when the bushings started to leak, going over bumps became a lot harsher. Also, the alignment started to show a higher negative camber, as indicated by the inside shoulder tread wear on the front tires. In our particular circumstance, didn't notice a change in caster, however I can imagine bad bushings would lead to any or all types of misalignments.
