tension rods 97Q45
q45huntsville
Car: 97 q45
What kind of problems would you notice when your tension rod are worn? I have 170,000 miles on my Q
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
In my case, steering wheel vibration and alignment issues.
q45huntsville
Car: 97 q45
Thanks,
I notice i get a slight vibration between 55 to 65 mph. Did you get that?
Q45tech
Between 55>65 mph the tire and rotor imbalance frequency and the body resonace frequency combine to be the most feelable range.
Since the brake pads slightly drags against rotors the vibration is always coupled.
The frequency of the vibration vs exact speed [mph] is what tells you exactly the rotating source in need of correction:
TIRES, wheel [without tires] rotor truing, bearings, etc.
The vibrations are always there, just that rubber wear u=in suspension isolators allows more and more to be felt.
On early Q I always replaced tension rods at 4 year or 60k intervals to minimize vibration transmission...........probably a great but expensive habit to continue thru today.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
The steering was really sloppy on mine at around 75k and replaced them and it made a huge difference. The issue with the tension rods is that they very slowly deteriorate to the point where you just accept the way the car steers, the same thing with shocks/struts, it regresses so slowly you don't notice it.
Trust me at 170k if those are original there is no way in heck they are still good.
NYCQDude
Car: '97 Infiniti Q45
Sounds like what I was experiencing before I replaced my tension rods less than a year ago (before my Q hit 90k). Could also be unevenly worn tires too, but I doubt it. Put the car on a lift and see what kind of play you have in your front end. If you are replacing the rods, replace the bushings too. If you are going to spend money, don't stop short of doing it right! The longer you let the shimmie go on, the more you risk wear on other parts because of the shake...
I agree with BadQ45t. At 170k miles they should have been replaced LONG ago!
q45huntsville
Car: 97 q45
Guys, do anyone have pictures of what bushings are needed to be replaced when i replace the tension rods. Might needs some instructions with that also. Thanks for all the replies
