Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Fri Jan 28, 2005 12:22 pm
It'll only take you about 1-2 hours max to replace the rods yourself. Bring PB Blaster or WD-40 and soak the bolts.
While you're at it, consider upgrading to pillowball rods w/spherical Heim joints instead of bushings...there are a ton of choices out there. I have the Battle Version rods which are very good.
You can also get rods with new bushings fitted already (PDM, Whiteline, Nismo etc.) if you don't feel like pressing the old ones out and the new ones in.
EDIT: as for the wheel falling off, prolly not going to happen. I drove around on split bushings for over a year and who knows how long they were busted before I bought the car. Not that I recommend doing so, but your car isn't going to self-destruct tomorrow because of bad bushings.
