unknown007 wrote:Well i rather ask for fast answers.Im screw i bought it.They are adjustable and i can make the short one the same size.The reason why it's smaller is they say because the steering.So now i have a short driver side and a long passenger tension rod.Should i just adjust them the same size?
You adjust the length to get the wheel exactly set to the alignment spec as measured on a Hunter alignment rack. Again, you have no business doing ANYTHING to a motor vehicle other than maybe filling the fuel tank until you gain a BASIC understanding of GENERIC automotive principles, much less the complexity of the Q. Why I keep suggesting a newer basic little car that doesnt require surgery would be a better{and safer for you and anyone around you} vehicle for you at your current level of automotive knowledge
