Gerardjg wrote:
If these rods are from another vehicle can someone look up the part number of the 70MM od bushing so I can order these.
all 94-97 J should use the same tension rod bushing, after some searching i still couldn't find out if the J use the same bushing as the (87-96) 300zx, (89-98) 240sx, which use the same bushing. If that 70MM bushing is from another car, i would guess that are for the Q45, BUT the Q use two different kind of bushings, too. one for the active suspension and one for the non-active suspension. Good luck.here is a couple good link.
http://www.ttzd.com/tech/tensionrodstec ... 00...l.htm
