Zing »
https://forums.nicoclub.com/zing-u8590.html
Sat May 01, 2004 12:50 pm
I tried to install SPL tension rod todayright side installed, pretty easy
while working on the passenger side, here's the problem:the bushing of the existing TC rod burst pretty bad and dislocated completely, i had a hard time removing the nut for the long bolt. Well, after i removed the nut, i can't push the long bolt out ! i tried to hammer it hardly, nothing happened, looks like the metal core inside the bushing is stuck permenantly with the bolt. Anybody have same kind of experience ? any help will be appreciated!
