gloucester Q »
https://forums.nicoclub.com/gloucester-q-u3303.html
Wed Sep 01, 2004 2:41 pm
i asked my local mechanic recently to replace the upper links and stabilizer bushings on the front end of my 93 q. i also handed him the tension rod bushings (p/n 54476-35F20). he replaced all but the tension rod bushings. he said when he took off one of the tension rods, it seemed as though the new bushing would not fit in properly. he measured the exsiting bushing on the car as 2 11/16 OD and the new bushings as 2 1/2 OD, leaving a 3/16 gap that neither he nor i could explain. he asked me to doublecheck the p/n before he hammered the old one out, so that's what i'm doing here. can anyone verify that this is the correct p/n for a 93 and if so, has anybody done this recently and did it seem at first that it might be a loose fit only to have it work out correctly in the end? many thanks. randy
