tension rod bracket mounting problem
Jayson240
hey all,
i was wondering how to access a certain bolt on the tension rod bracket closest to the LCA. it feels like it's held on the other side by a nut or something. i looked around from the bottom and under the hood and can't find an access point to the other side of the bolt. the FSM says that it's supposed to be a nut and the other two connections on the t/c bracket
to the frame are bolts (FA-4). car is a 92' 240sx.
thanks!
Jayson.
