gr8scott72 wrote:
Symptom of bad tension rod bushings are bad clunking sound coming from the front end while going over bumps.
Symptom of bad/warped rotors are vibration or shaking of front end while applying brakes.
Both need to be fixed.
I know the bushings are bad. I was thinking the rotor too. But it puzzles me that sometimes it'll do it just driving down the road. Which makes me think- Wheel Bearing. But I jacked up the car and it does not seem to have any slack in it. Any tell tale signs of the wheel bearing? Does it really cost THAT much? How hard is it to replace?
