I've been weighing my options, and with the prospect of a kid coming I'm not sure i could continue on this project. I'm just looking for a ball park figure for what this should go for with the given mods. Your help is appreciated guys.
Thanks,Driftfan420
1993 Nissan 240sx hatchback. No rust. 154K on the body, ~1K on newly built engine. I've had the car since 1997. One previous owner.
Drivetrain:
Nismo Engine/transmission mountsACT Heavy Duty 6puck sprung clutch Torque Capacity: 463 ft/lbs.Nismo steel braided Clutch lineVLSD2. Nismo Slave Cylinder and pivotFidanza lightweight fly wheel/ Fidanza Friction plateShaftmasters One piece Aluminum drive shaft W/ drive shaft safety loop Suspension:
Tein super street CoiloverSuspension technique sway barPeak Performance Urethane Subframe BushingsTanabe Sustec Strut Bar front/rearNismo Power Brace S13Nagisa Shakitto Shock Tower Plate 240SX '89-'94Tanabe fender brace
Braking Power:
Brembo slotted brake rotors ( Stock 240sx 4 bolt pattern)Hawk break padsAgency Power Stainless Steel Brake Line Kit Stock FrontAgency Power Stainless Steel Brake Line Kit Stock Rear
Engine Upgrade:
Top end: TODA SR20DE(T) Intake camshaft 264/10.5mm TODA SR20DE(T) Exhaust camshaft 264/10.5mm Ferrea Dual Valve Spring Kit for Nissan SR20DET Ferrea Valve seats Ferrea Titanium valve retainers Port Flow Manganese-Bronze Valve Guide Set Brian Crower Exhaust +.5 Valves for SR20DET Brian Crower Intake +.5 Valves for SR20DET ER Spec Stainless Rocker Arm Stoppers Cometic 1.1 87mm metal head gasket, Copper Exhaust gasket, Metal Turbo Gasket, ARP Head studs Bottom End:
-CP Pistons 86.5mm 9:0:1 compression-Eagle Connecting Rods with ARP hardware.-Main Bearings-Crank Bearings-Thrust Washers
Fuel System:2 Walbro 255 Fuel pumpsTomei 740cc InjectorsZ32 Fuel Filter Nissan SR20DET NGK Iridium Spark Plug Set for Nissan SR20DET (Heat 9)Sard Fuel Pressure Regulator hose type fittingLiquid filled Fuel Pressure Gauge
Power Upgrade:Garrett gt2871R turbo Taka S13 SR Bottom mount Turbo Lines:w/Taka Ball Bearing Oil RestrictorGodspeed intercooler w/ custom intercooler pipingHKS ssqv BOV w/ custom pipingGreddy intake plenium (polished)Snow Performance Stage 2 Methanol KitTomei exhaust manifold (heat wrapped)Tomei exhaust elbow
Engine Cosmetics:
Flex-A-Lite model 345 Dual fans Power Enterprise Super V-Belt (Kevlar) S13SR-Belt-Set/Main,P/S,A/CGreddy SR20DET Oil Pan Megan Racing S13 SR20DET Light Weight Pully SetSamco hoses ( radiator, couplers, etc.)Greddy Oil Filter Relocation Kit for Nissan S13 SR20DET MA powersteering custom line (powersteering line)Color BlueMegan Racing 1 3/8 water temp adapter Circuit sports polished coolant tankKoyo RadiatorNISMO SR20DET Grounding kit(4 Gauge)
Interior Upgrade:
2 Sparco evo2 (XL)racing seats 2 Willans racing harness CUsco Custom 4 Point Roll Cage w/ harness bar Nissan 240SX S13 91-93 Roll Bar Padding - SFI Spec 45.1 Rollbar Padding ATI EZ-Pod : S13 89-94 240SXCarbon Fiber door panelsMomo Stealth foot pedalsMomo Stealth FootrestMomo Aluminum grid floor matMomo Floor matsMomo shift knobMomo leather shiftbootMomo stealth EbrakeMomo Ebrake leather bootMomo GTR2 steering wheelNRG Gen 2.5 quick release adapterSplash short boss Steering Hub
Gauges/Controllers:
Haltech E8 ECU w/ Map sensor Air temp sensor TPS sensorDual stage shift lightCoolant temp sensorGreddy Turbo TimerAEM Uego (Wideband)AEM TRU-BOOST Gauge-Type ControllerSaga Technik Gauges (fuel pres, oil pres, oil temp, water temp, Boost )
Audio:
2 8” Rockford fosgate sub2 10” Rockford Fosgate Sub2 6 1/2 “ Kicker door speakers4 Kicker 100watt dome tweeters1 Rockford fosgate P-400 amp1 Rockford fosgate P-200 ampCustom sub enclosure/ amp rackKenwood deck w/ USB connection
Exterior:
Dmax crystal rear tail lightsNew Wheel well inner covers
