temporary suspension setup
mr_wizard
I desperatley need suspension, or atleast lowered. I gutted my s13 so its sits a couple inch's higher. I plan to use the car as a dd and autox at some point. But, I don't have cash to do a whole setup. I'm wondering if I could get some coilovers with my stock suspension to temporarly lower it and help handeling a little bit, then when I can get the struts and everything these will work with them, so I don't waste cash. any suggestions?
chmercer
that would deffinitley be a waste of cash. sleeve overs are cheap junk, and you will spend more getting them installed than it is worth.
babowc
Car: 240sx
sry.. bit off topic.. but where in richmond are you located??i used to live there.. nice to see a person from my old hometown
anyways, sleeves like chmercer said are junk.gutting can make the car sit couple (2) inches higher?... if you want to go ghetto.. although a bad idea, just cut the springs? haha.. im nt recommending it, though!
mr_wizard
Im in glen allen actually, near the vcc area. But yea, i think I exagerated, it's probably about an inch. Even so it still looks bad :-P So what do you guys suggest to do?
chmercer
save up for entry level coilovers is what i would do
