Victor »
https://forums.nicoclub.com/victor-u94029.html
Mon Apr 07, 2008 6:39 pm
I have a 94 J30T with 191,400 miles on it and it has a few annoying problems that don't keep it from driving, and I don't want to spend a whole lot of time and money trying to fix when the car is nearing the end of its life. But anyway, here are some of them and quick fixes. If anyone has any permanent fixes please post them, or if you know any other quick temporary fixes post them too.
1. Dashboard instrument lights go out. Tap on dimmer control to fix.
2. Remote control door locks won't work. Fix, use the key.
3. Power door locks try to lock you in the car. Pull out the manual door lock lever, even as it tries to fight you making a buzzing noise.
4. Windshield wipers get stuck in up position when turning them off. Quick fix, keep turning them on and off and try to turn them off while they are moving down, Eventually the will stop where you want them to. On another thread someone said the windshield wiper relay is the cause.
5. Right low beam headlight sometimes won't light even though bulb is good. For some reason switching the bulbs from the left and right sides of the car fixed my problem permanently. I didn't put in new bulbs, just swapped them.
6. Parking brake on light lit even though you pulled the brake release. Stick your toe under the parking brake pedal and lift it upwards while pulling on the parking brake release. If it moves it was sticking.
