tempeture gauge
93low240sx
Car: mostly working on cars
My cars tempeture gauge keeps going up, but only when i accelerate.I checked the coolant and its fine! do you think it could be the water pump? I really have no idea on this one. Please help!Tempeture Gauge?
93low240sx
no its not moving with the speedometer, but my tempeture goes up then it goes down and so on. yes i checked my coolant.
93low240sx
it might i havent tried.
s0ldats
my temperature gauge bounces up and down (or pegs..whatever the right term is) when i rev the engine ...could it be the sensor? is it an expensive fix?
1991240xs
i was having similar problems 93low...and mine was the thermostat..just make sure you seal everything up with a felpro(or whatever brand) gasket..and some gasket sealer...but i also had a problem with my radiator(visible crack in the plastic)..let us know how it goes
93low240sx
how much do u think a new thermostat would go for?
slw240sx
Car: 1990 Ca18det 240sx Hatch
3-6$ and its a pain an the as5 to do in the cold an dark on a Ka24e.. when mine went out i think it was the problem. the temp gauge would fall every time i WOT it... and the heat wasnt hot.. well i replaced it an the gauge works but ive never seen it go past half way. ever in the 2yrs i had it never past half...well after i changed it the damn thermostat stuck open an the car wouldnt heat up even idling for ever i didnt have heat for 2weeks but it has mysteriously fixed itself an i got heat again..... my passenger floor boards been real wet lately so i may have a bad core
93low240sx
yea i noticed that my heat isnt hot it blows warm air, so i think your right on the thermastat, what else did you replace? just the thermostat?
slw240sx
yeah just the thermostat
