temperature went slightly up
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
i was wondering if i would need to put my water cool lines on my t25?rite now the water cool lines arent on and the temperature from my car just barely went slightly up.is that supposed to be normal?it just happen today (regular driving)
im running 5w30 royal purple oil and i havent done any beating to the motor because im not tune til next week.just waiting until my injectors get here
480sx
Car: 1996 Pearl White 240sx
You dont have to run them but they will extend the life of your turbo.
Having a water cooled turbo eliminates heat-soak, which cakes the oil in your turbo and will cause poor lubrication. Eventually it will eat your bearings due to oil starvation. Letting your turbo cool off for a while with a turbo timer or just leaving your car running after you drive stops this for the most part though.
Also for extended highway driving a water cooled turbo is recommended, it keeps your IAT's lower, and your turbo cooler.
I dont really understand about your car running a bit hotter. This happend after you installed your turbo kit? That doesnt really make any sense. If it only raised it a little bit you dont have anything to worry about. You might have a few rails in your radiator stoped up or something.
240sxvaj
[QUOTE=480sx]Also for extended highway driving a water cooled turbo is recommended, it keeps your IAT's lower, and your turbo cooler.QUOTE]
IAT?
im not too sure on the temp. thoughmy car ran fine before i turbo it and i turbo it about a month ago and it was running fine. but then i think its just me.
i'll let you know how it turns out after a couple of days.
thanks
480sx
Sorry, IAT = intake air temp
neverlift
if its stock temp gauge then I wouldnt trust it lol, blow ka 1 due to lying *** temp gauge, autometer/
