Temperature gauge is out need help
kboonhower
Well my temperature gauge stopped working in my car it sits about 1/3 up from the bottom of the gauge. I bought a new sensor to see if that was the problem but i can not find the old one on the engine to replace could some one please explain to me how to find it my car and i would be very thankful.
Thanks, Kevin
NISTECH
on the intake manifold near the front where the upper most hose for the radiator is connected. I suspect its not your sender though. typically when the sender goes bad it either goes to full hot or full cold. I think your gauge may be the fault or a partial short to ground in the harness. if it were the harness I would think the gauge would fluctuate. To determine if it is infact the sender try disconnecting it and turning the key on. it should go to the full cold position. and if you short it to ground the gauge should go full hot. If it does then that proves the rest of the circuit is functioning properly. if not then you have a problem somewhere else in the circuit.
240sxgirl
Car: Hot guys, fast cars, both at once.
I have the same problem. My tach and temp gauge dont work and they both did before I took it to the body shop and had the frame cut from another car and welded on mine. I suspect the bodyshop didnt hook all the wires back up. I have a purple wire hanging all by itself but I cant see any other wires hanging down.
kboonhower
Thanks for the help, once i get a chance to work on it ill let yall know what it was.
kboonhower
Well it wasnt the sender, so how hard is it the replace the gauge is it a complete unit (tach, speedo) or can i just get the temparture gauge. Thanks
NISTECH
you should be able to get just the temp gauge by itself. they arent to common to burn up on nissans so you could probably find a good one at a wreakin yard
kboonhower
I found one at a local salvage yard but he wouldn't seperate the gauges and he wanted $125 for the whole assembly. Is this to much or what i should expect to pay.
Thanks for any and all input, Kevin
NISTECH
check at the dealer or a parts house in your area or even through the wholesale parts on this forum. it might be cheaper just to buy the temp gauge its self new.
TogueDrifter
Car: 91 B13 SER
I have the same problem with my temp gauge. However mine stays at cold at all times. I tryed testing my CTS, and if I did it right I think it's my gauge or an open. How would I know if its the CTS or the gauge itself?
NISTECH
did you test the single wire sensor or 2 wire sensor? The single wire one is for the gauge.
