temperature gauge at H and car just clicks now, wont start.
bassboy3313
Car: 1991 240sx hatchback
Hey. I just got a catback installed on my car. when i got it back and pulled it in the driveway i noticed my temp gauge was just below the H mark. I popped the hood and the coolant in the overflow tank was well above the MAX line. the temp gauge sat just below the H mark for awhile. I turned on the heat in the car and the temp gauge went to H, then when i turned off the heat it dropped down back to just below the H.
Anyone have a solution?
UPDATE: The car does not start after letting it cool down for over an hour. It makes a clicking noise but nothing happens. now what?
could it have nothing to do with the temperature and be a bad altnernator or battery or something?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Is it your Hyundai, or do you have a 240?
angrypenguin182
Car: 91' Nissan 240sx
check your hoses, and probably your thermostat. does your heater still work? and hope you didnt blow the headgasket lol
bassboy3313
oh im sorry. i parted the hyundai out and bought a 91 240sx. its the 240 that doesnt start and stuff.
heater still works and hoses are fine.
the main issue now is the non-starting and the clicking. im gonna check the starter right now. im guessing its either the starter or alternator since the battery is new.
angrypenguin182
If u hear clicking ur starter might still be fine lightly hit it w/ a hammer and see if it strats if it does then it is ur starter
bassboy3313
i have tried that procedure and it still does not start. the clicking noise sounds like it is coming from the starter or somewhere near the intake manifold.
greencar
Car: 1992 240sx se
bassboy3313
thanks. im just stumped on what i should do.
angrypenguin182
If you have the time take out both alternator and starter and go get them tested, I know advanced tests them not too sure on other auto stores cuz I live across from advanced auto
bassboy3313
i removed the starter and took it to auto zone and oreilly to get it tested. both places passed the test, so the starter is good. they said the alternator would have nothing to do with it since it has a brand new battery i just put in after this all started happening. they said it could have something to do with the flywheel not connecting with the starter or something in that range.
what do you all think?
greencar
Car: 1992 240sx se
Check starter relay, Bypass the starter relay with the link above, and is your car a manual? have you tried manually turning the crank with a big a** wrench? have you tried to push start it?
-Dan
bassboy3313
what does the relay look like? how would you bypass it?
bassboy3313
yes my car is manual. the crank fan turns slightly when the clicking is going on. no i havent tried push starting either.
greencar
Car: 1992 240sx se
try push starting it or using a big a** wrench to turn the crank. You may also want to pull the spark plugs and try cranking it that way too.
-dan
bassboy3313
kinda hard to do these things when its a blizzard outside. might be taking it to a shop to get it fixed.
CTS13
Car: 91 240sx, 02 Camry, 09 Gsxr600
Why would you check the starter after overheating the motor. Check to see if the motor turns manually. You could have locked it up or blown a heagasket or maybe, damaged pistons rings. Eiather way, if your motor doesnt turn while tryin to start, youv locked it up.
bassboy3313
when trying to start it, the fan shaft moved slightly while its clicking. it seems like it wants to turn, but just doesnt have the power to or whatever.
CTS13
Okay, take a ratchet or breaker bar and try to spin the crank by hand. Hopefully your not 6 feet tall weighing 20 lbs cuz itll take some effort. see if you can spin it good 3 turns without killing your back.
bassboy3313
yeah that prolly wont happen. we got a blizzard going on here. lol. damn snow!!
CTS13
Wait hold on. you drive a rust bucket in the snow? and wait, you just installed a catback at this time of the year and hold the fug up, you paid to install a catback?
lol. im just fuggin wicha.
bassboy3313
haha! yes i do! well, technically i havent drove it in the snow yet since it wont start. lmao!!
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
I know you got a new battery, but have you had it tested under load? you may have gotten a bad battery from the get go.
bassboy3313
turns out it was the starter. thats the last time i take a part to an auto store to get tested. repair shop said they tested it and it didnt do anything unless they hit it with a hammer.
just my luck!
now its just figuring out the bogging during acceleration and the high idle at a stand still.
