Temperature/Compass Gauge
cmkelly
Car: 1992 Nissan 240SX Vert
2006 Acura TL
2001 Nissan Pathfinder LE
1996 Toyota 4Runner 4x4
Is anyone else's temperature gauge off by about 5 degrees? Is there a way to calibrate this gauge?
I tried searching but didn't find this topic.
Thanks
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
:o usually like 2-3 for me. . I, too, would like to calibrate it.
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
where the sensor is positioned, it isnt the best spot for a temp sensor.
cmkelly
2006 Acura TL
Yeah, and my Pathfinder's black which probably doesn't help. Still, when I hold the button (to change the degrees to either C or F) in long enough it starts to blink and then gives me the ability to set it to any number bwtween 1 and 12. What the heck does that do? Anyone know?
Regards,
Chris
KoukiS14
cmkelly wrote:Yeah, and my Pathfinder's black which probably doesn't help. Still, when I hold the button (to change the degrees to either C or F) in long enough it starts to blink and then gives me the ability to set it to any number bwtween 1 and 12. What the heck does that do? Anyone know?
Regards,
Chris
It's for the magnetic compass deviation -- you can set this for a more accurate compass reading depending on where you live.If you don't have the owner's manual, I can send a PDF of that soon.
bullrid
Car: 01 Pathfinder LE
Regards,
Chris
this selection of numbers allows you to move from east coast to west coast and keep your compass calibrated correctly the entire way. because the magnetic north is slightly different then true north, you have to adjust the compass for your location.
