Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Tue Nov 02, 2004 4:18 am
iirc, the OEM R32 thermo switch comes on at 90ºC and goes back of at 80ºC (194 and 176 in ºF). If you run the R32 radiator, you can just use that switch. If you run an aftermarket switch, then you should use those numbers as guidelines.
Personally, I would switch both fans. The thermostat doesn't even crack open until over 74ºC, so you'd just be wasting electricity. Also, running the engine too cold will hurt your efficiency.
