i would post this in technical but it seems like nobody is ever in there anymore.
as soon as i turn the key one click in my car to give power to everything the temp sensor in the cluster shoots way past the H even when the car hasnt been driven in days. so far ive replaced the gauge itself in the cluster whith one from a sohc cluster and it does the exact same thing. ive also replaced the two temp sensors in the motor with new ones. since it happens every time i give it power im thinking some wiring is messed up but all my grounds are grounded and the correct wire was soldered together when i did my harness according to
http://www.frsport.com/SR20DET-Swap-Eng ... _t_26.html
blue/black stripe wire is the water temp signal to the dash and thats what i have so im not sure how much more wiring could go into a small thing like this.
any help is appreciated.
