qmccall wrote:Nistech.......does the temp sensor control fuel circulation in any way? how do u know when a fuel pump is going bad? and when do change the fuel pump in the I30(1996) do u clean the tank? if so, how?
The Coolant temp does not have any control over the fuel pump/pressure. The fuel pump is active anytime the car is running or when the key is cycled from off to on it runs for about 5 secs. The only way fuel pressure is controled is b the fuel pressure regulator which is controled by intake vaccum. less vaccum in the intake manifold means higher fuel pressure. This is done by restricting the fuel from returning to the tank at the fuel pressure regulator. This is the only device in the entire fuel system that has any effect on fuel pressure. Pump speed is never varied or cycled on your car.
The coolant temp sensor has an effect on injector open time when its cold. It sends a signal to the ECM and that determines if the vehicle needs additional fuel to keep the car running when cold. Once the car warms up the coolant temp sensor is out of the loop and O2 is used primarily by the ecm to determine injector open time. Note though these are not the only sensors that determine open time but are a couple of the primary ones, Mass airflow sensor is the most important one on the car.
To determine if the pump is goin south use a fuel gauge and see if the readings are with in spec. should be around 36psi at idle and when the fuel pressure reg vaccum hose is pulled off it should jump to about 43 psi.
Claening the tank is really not neccesary unless you have heavy sediment in it then yes. But that is not usualy the case unless you are buying crappy fuel.
