coupebuddy wrote:ok I have a 96 motor w 93 harness and auto ecu steel auto radiator new temp sensors(both) new radiator cap.my car has been plauged w this overheating problem.I have no heater and the water hoses has a bypass from rad inlet to outlet (between intake mani & block)I realized that the heater 1 heater outlets(the rear 1)still has water going to it so I flushed the sys per the specs allowing water 2 blow out the line then fill it with the bleeder out.highway driving at normal speeds is now perfect (city 2).but if I travel 110-120 for 5min or more temp rises quik.also did blok sealer and no water in oil and no oil in coolant not even the smell in coolant so I do not suspect head gasket can any help I would hope I know my **** cause I do motor swaps and rebuilds all the time (3rd hustle)but I just cant seem to peg this ****.so some feed back pleeze
i have .. but like he said not for 5 mins.tonynalli wrote:my god people you act like youve never driven over 120 mph...so all of yall shut up...try your waterpump..could be the problem..not sure
Tell you what. Why don't you two ride together so we can kill two birds with one stone.tonynalli wrote:my god people you act like youve never driven over 120 mph...so all of yall shut up...try your waterpump..could be the problem..not sure
This thread is over now......tryiian wrote:uh, yeah,
No way people get away with that on a regular basis in any major city with a functioning highway patrol. That aside, most cars I see on the road are either incapable of going 120 stock or would be pushed to their limits to reach that kind of speeds. So much for the idea that he was doing it somewhere more sensible, he should`ve just not bothered mentioning where or why he`s going that fast and stuck with the benefit of the doubt people were giving him.
...actually, i drive in.. uh.. "laddy daddy" every day... and no one drives a buck 20 on i75 ... you are just a jackass.coupebuddy wrote:I drive on i75 in ft laddy daddy fl where speed limit is 75mmph and eveyone drives 120 also theres 7 lanes so an experienced driver can handle it.I may try an oil cooler .water pump,or vent the hood all I know is when I slow down the temp goes down.
