AZhitman wrote:D I still prefer the lower hose arrangement, but I'd be open to have my opinion corrected by someone more knowledgeable.
Can I give it a quick shot?
Ok, I learned all about control systems in my engineering courses, and we did go over stuff similar to this. The only real difference is that we were usually talking about a process (like heating beer as it is being made or something like that).
Anyway, the thing we want to know is the temperature of the engine, not the temperature of the radiator. For our purposes, we shouldn't really care what temperature the coolant is coming into the engine at, only what it is leaving at, since THAT will be what temp the engine is actually running at. If you're having some huge problem with the engine and it is generating way too much heat (say, leaning out or something) then the coolant coming out of it is gonna be hotter. If the coolant then goes into the rad and is cooled down just as much as normal, to whatever minimum temp it can, then your gauge mounted in the return hose would read that minimum temp, and you may be oblivious to a problem.
Errr.. hope that makes sense. I just woke up a few minutes ago...
