MikeMurphy wrote:Wow, nobody tells the guy that ITS NORMAL!?
Trpower7 explained it. As long as the water temp is within an acceptable range, the stock gauge is going to tell you only that much info. If your car is ready to puke up some vital fluids, the gauge will (hopefully) let you know in time to pull over and shut the damn car off!
It's an "idiot light" just like the OE oil pressure light. If you really want to monitor your water temp, there are plenty of real gauges to monitor temp, oil pressure, etc.
Anyway, Uno, as long as your car isn't showing any signs of overheating, don't worry about the gauge. It sounds like it's functioning exactly as designed.
Edit: Have a beer, go to your happy place, relax. Enjoy your car.
