beachfan »
https://forums.nicoclub.com/beachfan-u61424.html
Mon Apr 02, 2007 10:30 am
Hello all, 1990 q-45 temp gauge recently started jumping around rapidly then went all the way to C then jittered some more then ended up where it was before about half way between H and C (think this is actual temp) then repeated the problem. Any thoughts on cause? Also experincing rough idle think it may be plugs or fuel injectors could that be related to temp gauge failure? thanks in advance for your input
