temp gauge not working
jrock7885
Car: 1989 Nissan 240sx RB20DET
just installed rb 20 in 90 s13 and temp guge does not work so i installed an after market one but it does not work either the needle goes all the way to 280 degrees and i know the tach is not supose to read properly cuz its a single cam cluster but i thought it woul atleast try to work but its not doing anything any suggestions.
lilskyline240
Car: 90 240sx w/ rb30det
in order to use the stock cluster temp gauge u need to replace the temp sensor with the KA one
Joe
did you use the sender provided with the aftermarket gauge?
jrock7885
no i didnt replace it so i will do the temp sensor 2day and i didnt replace the aftermarket one duh i wasnt thinking.
lilskyline240
just replace the Rb one with your KA one and ull be good to go as long as you wired it all up correctly
jrock7885
well i have a single cam if thats is any different from dohc sensor but i replaced the rb sensor with the sohc sensor and my temp still didnt workso i dont know wat it could be now but ill keep looking.
