DailyDriver »
https://forums.nicoclub.com/dailydriver-u11992.html
Fri Dec 12, 2003 7:18 am
I have the same problem. After my radiator blew, I replaced the radiator and hoses and bled the system. I then noticed irregular temp problems, the car does fine until warm, then proceeds to spit coolant into the overfill causing the temp gauge to vary from cold to almost hot and changes during acceleration. It doesn't overheat, just kind of boils. The lower radiator hose doesn't get real warm, so I replaced the thermostat. Still doing the same thing. Does anyone know how to fix this? I was thinking maybe the water pump (the only part I haven't replaced), but normally water pumps leak, not restrict flow. Any help would be greatly appreciated. Thanks!
