S13240 »
https://forums.nicoclub.com/s13240-u302.html
Wed Jul 13, 2005 2:39 pm
Just got the drain plug fixed yesterday after I posted this problem. It looks like it may be the thermostat as it only happens under load. I've bled the cooling system 4 times the past two weeks even with the small leak before and no air bubbles to be found. Not low on coolant either as I check it every day. I just drove it in 110+ degrees today coming back home from work and it drives fine. Haven't tried uphill yet, but it's guaranteed that the temp will climb up fast.
