temp gauge
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
72oh
Car: 1986 720 4x4
Hey guys! This is my first post. First of all, I just bought an 86 720 4x4. Thing runs like a top but obviously will need some tlc. My question is has anyone had experience with a bad temp gauge? Mine stays below cold. I will check to see if it is disconnected at the sensor today as this will be the first chance I get at checking it. Just thought I would post this now to give time for responses. I will have other questions later as there are a number of small things I would like to repair.
thanks,
Keith
bob_reynolds
Car: Nissan 720
This might be another one of those Quirks.
I have an '86 720 and the temp gauge hardly gets above the cold line at the bottom.
captainzeros
Car:
1981 Datsun 720 Longbed
1973 Datsun 240Z
My gauge usually hangs out about here, and I know it works cause once I lost my fan belt and bang-zoom, way hot.
Kira-Hachi
Car: 1990 Sileighty / 1986 720 KingCab
Mine gets to just below half when fully warmed. Unless I'm going 110 km/h (60mph) in a -40 day then it dips to 1/8 lol.
72oh
Car: 1986 720 4x4
dangit!! Hey, does anyone know where the temperature sender is? I think I can figure this out if I know how it is wired. And ofcourse, my gas gauge is not working either!
bracktheron720
Car: 1984 720 with 1980 datsun front end,1972 yamaha cs3
im pretty sure its this little guy just under the top radiator hose in the intake manifold..let me know if im wronge!!lol mine doesnt really do much eather if anything l dont really know...let us know if you get it figured out!
moredunes720
Car: 1985 nissan 720 4x4
I have a theory that these trucks, under normal operation, especially the napz, run fairly cool. I installed an aftermarket manual temp gauge, I can only get the temp to go up when in 4wd for a long time when my clutch fan on the water pump worked. I know the gauge is accurate, since it manual, meaning no electric sending unit.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Mine works great. It's usually about 1/4 but goes through the whole range as I had a leaking radiator.
72oh
Car: 1986 720 4x4
Started it up the other day and both the temp gauge and the fuel gauge began working. Been working ever since!
I think the problem may be with grounding...
flinterman2000
On all vehicles grounding is a real problem. We need to check this aspect of the vehicles more often.
72oh
Car: 1986 720 4x4
they ain't workin' again! AAARRGGHHH!!!
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Welcome to Nico Keith
PEZi
sounds like you have a few gauge issues overall man... but everything that has been said about these trucks running cool is true
with all the stuff i have removed from the bay, and the extra cooling i have added.... i will NEVER get close to half way on my temp gauge unless i lose the belt
72oh
Car: 1986 720 4x4
Thanks, man!
By the way, when the gauge decides to work, it runs just where I think it ought to-- right inbetween cold and middle (a quarter of the way up). So I am not worried about the temp, just would like to be able to monitor it!
Return to “Datsun 720”
