howie »
https://forums.nicoclub.com/howie-u136781.html
Fri Jul 29, 2011 10:43 am
1999.5 QX4
Coolant was flushed by Midas in the last year.
Issue: Temperature gauge showing "too hot" when idling, but running the engine brings the gauge back down.
I start the car from cold and let it run...
The temp will go to "in the middle" (9 o'clock, where I expect) and then keep rising to 11 o'clock within 5 minutes.
If I start driving at about--or faster--than 40 mph for a few minutes, it will drop back to "normal" (9 o'clock).
If I get stuck in traffic or sit at a long stop light and have to idle again, the gauge will rise back up to 11 o'clock or 11:30 within a couple minutes (varies...like 2-5 minutes).
Here's the twist:
If I'm idling with the gauge reading "hot" (11 o'clock) and I go into Neutral and press the accelerator to hold the engine at 2500-3000 RPMs, then the temp will drop back to "normal" within 2 minutes.
So running the engine seems to cool the engine off (or at least the gauge).
It's been about 80-90 degrees F outside here. I'm sure pulling air across the engine helps, but if simply running the engine cools it off, that seems a little confusing to me.
I've changed my oil & brake pads but not much else. Not sure if another coolant flush would help. Is this a problem with the gauge? I'm sure it needs to be fixed, whatever it is, but I'm not sure what the diagnosis should be.
Oh yeah, the running the heater thing...
Yes, I've been using the A/C.
Turning the fans on at the highest temp in the display (85 degrees F) and blowing at "four fans" through the foot and face blowers has not seemed to help too much but I have not explored it a lot, either... I know this is often suggested for engines overheating... this worked for my old '94 Mazda 626 sedan but I'm not sure if it works the same with the Infinity's computer / system or not, actually. In any case it's a short term solution and I really want to know what needs to be done to fix it at this point.
Thanks for any thoughts. I'll be able to answer any questions to provide more info as well.
