s13redmon »
https://forums.nicoclub.com/s13redmon-u102821.html
Wed Oct 20, 2010 5:15 pm
Ok, i just swapped a ka24de into my 1990 240 and it's reading high on the temp gauge but it doesn't seem like its actually running hot. I can let it sit and idle and it will stay at about 2.5 lines on the temp gauge but when i take it out and drive it shoots almost up to hot and the higher i rev it, the faster/ higher the gauge goes. I didn't put in a ka24e temp sensor so i'm wondering exactly how much of a difference that would make as far as the gauge reading. Also, with the heat on full blast the air coming out isn't that warm, even when the gauge is on the last line before hot, so I'm wondering if the thermostat (brand new) could be the problem.
