emt-z »
https://forums.nicoclub.com/emt-z-u160625.html
Wed Jun 02, 2010 2:53 pm
hey z fans i have a problem with my z for around a year and a half now, i used the search function and found no useful info relevant to my problem- forgive me if i missed it somewhere. my temp gauge shows that it is warm at all times, by warm i mean half way through its given range. it does not matter how long it sits untouched, if its overnight or longer. it has done this since before i replaced my egi harness and both sensors on the front of the car. the gauge shows the same plugged or un-plugged. the using a test light on the single wire causes the light to light dimly but shows to have eleven volts or so voming to the sensor. the sensor shows to have a varying resistance to ground at different temps so i figure it to still be good 9correct me if i am wrong plz).
my only guess is that the computer has messed up inside since all harness wires run to it, or the gauge is messed up somehow.
anyone else seen this before? any ideas?
the sensor i am messing with is the single pole, the other i believe is the sensor for the computer. the only way i know the temp is to hook up my laptop to the car's computer and watch it that way, trying to get this fixed before we head off to florida in her in a couple weeks.
