temp gauge on cluster not working on Sr
sil8t
my problem was the temp gauge..Since i swapped an sr..It doesnt read.. All of the others like my tach, and speedo work..my cars an 89. Im not sure if its compatible with the wiring on the sr. I see some people buy the 91-94 gauge cluster, and i dont kno the results of that. Can anyone explain if that would be a good idea..or would even work?
robbbby
You have an '89 240 and swapped a redtop into it and didn't change your gauge cluster, and the tachometer is working?
sil8t
I swapped in an s14 in my s13.. what i didnt include was that.. i bought a 180sx cluster gauge with the 180 km setting..It said that it would work just fine..but ran across the temp problem..
proimport17
Car: motocross, baseball
You have to use the temp sender from the ka motor is you use the ka instrument cluster
