Temp gauge not working
rosyjazz
We were working on installing a deck when a wire went pop. Now the temp gauge isn't working? What to check?
rosyjazz
whoops...its a 97 pathy
4xq
Well, fuse probably blew. Check the fuses under the left side of the dash.
rosyjazz
4xq wrote:Well, fuse probably blew. Check the fuses under the left side of the dash.
we did that..all were fine.
4xq
Your speedomter and tachometer are on that same fuse. If they still work, the fuse is good, and either the temp gauge or the sending unit is damaged.
Check page EL-86 and EL-87 in the service manual I linked you to.
rosyjazz
weird, but its working now
