Temp gauge not working
joesabr
Car: Nissan Sentra SE R Spec V
I have a 2002 Nissan sentra SE R Spec V and my temp gauge is not working at all, I have no clue what could be causing it. It's not the cluster because I got a new one, and still didn't do any thing. Any suggestions?
Modified by joesabr at 7:13 PM 5/31/2009
ProudNissanFreak
Car: 2005 Imaginary WRX STi, 2003 Civic
Your temperature sensor has gone bad.
Modified by ProudNissanFreak at 7:16 PM 5/31/2009
joesabr
Where is the sensor located?
ProudNissanFreak
Best way to find it is:
a) Looks it up in a Hayne's Repair Guideb) Get into the gauge cluster, pull out the temperature gauge, trace the wires attached to the sensor.
The sensor will be screwed into the necessary equipment, so be sure you have the tools to get it out.
nametakennow
Car: '06 MINI Cooper S
Water temp sensor or combination meter malfunction. You can check it with the procedure on EL-94 in the FSM - this isn't the SE-R FSM, but it should be the same procedure - http://www.nicoclub.com/FSM/Se...l.pdf
If the test shows up like in the picture and the gauges sweep smoothly and easily, your combo meter is bad. If your temp gauge doesn't act right in the test, the temp sensor is bad. Probably the sensor itself. Fairly common failure.
Grab your FSM here - http://www.nicoclub.com/FSM/Sentra/ - for replacement instructions.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Take your car to nissan. You will more than likely need a new ECU. This happened on my wife's car and I changed everything that could possibly affect the gauge and nothing worked. I even switched out clusters. Nissan has to cover the ECU under 8yr/80k mile warranty.
