compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Sat Feb 20, 2010 10:40 pm
Sounds like gauge cluster. You can test it by cutting the wire that goes to the single wire temp sensor and taking wire and cutting the wire on the back of the gauge cluster for temp sensor and running a wire From one to the other. Get your car warmed up and if your gauge works , well id just stick with that wire. If not solder everything back up and do more diagnostics. I to this dy had the same problem and never removed my test wire because it simply worked for me.
