Ok thanks! My original gauge isn't working it goes crazy it'll read above hot after just turning on the car then it'll stop working all of a sudden. So is it possible to still do that check?KDS_cars wrote: ↑Wed Mar 07, 2018 6:06 pmIf able i would look to see if the same voltages read the same temp. If 5 volts on on is max vs maybe 12 on the other you could could pin the gauge. if all if good then maybe pull the needle and plate of the original and put the plate on the new one so the alignment pins all line up. or drill holes on the new one to mach the old.
Yeah that’s what I’m going to do I’m not really too adept with this part of the car. So I don’t want to mess with things to much because if not I’ll break it. Thinking about buying a full gauge cluster.DCaff300ZX wrote: ↑Fri Mar 09, 2018 9:40 amI personally would hunt down the correct part, this isn't an area I'd do any jury-rigging or other modifications. The classifieds generally have parting-out cars listed, I'd work from classi's to find my part or also consider used parts from Z1 in this case.
Good choice. I MAY have one for you from my '89/'90NA, just haven't decided to part with it yet. Has the chrome gauge rings installed, plastic cover is in pretty good shape...let me know if you are interested.zLover32 wrote: ↑Fri Mar 09, 2018 10:09 amYeah that’s what I’m going to do I’m not really too adept with this part of the car. So I don’t want to mess with things to much because if not I’ll break it. Thinking about buying a full gauge cluster.DCaff300ZX wrote: ↑Fri Mar 09, 2018 9:40 amI personally would hunt down the correct part, this isn't an area I'd do any jury-rigging or other modifications. The classifieds generally have parting-out cars listed, I'd work from classi's to find my part or also consider used parts from Z1 in this case.
DCaff300ZX wrote: ↑Sun Mar 11, 2018 9:27 amGood choice. I MAY have one for you from my '89/'90NA, just haven't decided to part with it yet. Has the chrome gauge rings installed, plastic cover is in pretty good shape...let me know if you are interested.
