telling the difference from tt and n/a diffs
allmtoreg
Car: 93 240sx coupe
I just bought a whole rear subframe off this dude who assured me it was an n/a setup. Upon disassembly I find it has the tt hubs with the tab on the top with the spacer for the ebrake. I am completely furious since i put alot of money and effort to pick this up. Is there a way to tell if the diff is a tt too? Chances are it is but I wanna make sure just incase some parts got swapped around or something. Yes I did search but I'm on my iPhone and it's hard to search for a specific question like this. Any input? Thanks
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I assume this is from a z32? If the axles are TT splined your can figure the diff is too, if you want to verify, just measure the ring gear it will be 230mm
allmtoreg
Car: 93 240sx coupe
Yes z32
hilux30
Car: 2007 Tacoma 4x4
the TT has a 3.69 gear ratio and the N/A has a 4.083 ratio, is that why you pissed 'cause you wanted the 4.+ diff?
car nut
Car: GT500.
hilux30 wrote:the TT has a 3.69 gear ratio and the N/A has a 4.083 ratio, is that why you pissed 'cause you wanted the 4.+ diff?
It's also a lot more work to get into an S chassis. OP, unless the guy swapped an R200 into the TT subframe (which isn't easy) it's more then likely a TT diff. I'd try and get your money back.
hilux30
I tot all TTs have HICAS and all n/a don't?? no? yes?
sean@z1
Car: 1993 240sx
The TT Sub frame dose not have the damaners at the front of it the TT sub frame has HICAS The TT Diff is wider than the R200 in the S13 and the NA is a R200 with the ABS sensors
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
Open up the diff and count the number of teeth on the ring gear.49 teeth = Z32 n/a (same as a stock 240 open diff)47 teeth = Z32 TT
Z32 n/a w/ automatic have no heat sink on their diff covers, but are lsd's.Manual's do have the heat sink.
This may help:http://www.ka24development.com/vlsd.html
allmtoreg
Car: 93 240sx coupe
thanks for the info guys. i will take pics when i get home
r3v_v3ng3
Car: 91 fastback ka-t
also look at the axle/output flange if its 6 (single) bolts then its TT the na has 5 bolts
