tell what u guys think of my project car so far.......
rb26ishere
Car: 240sx coupe with a rb26dett and vmount
so heres my car get close to getting done. 93 coupe with a rb26dett and a v-mount setup. heres a couple pics
http://s662.photobucket.com/albums/uu347/ttr232/
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
Very nice man,looks good.This is a general question,but what are the advantages to a v-mount setup as opposed to standard?
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
ARC! Nice!
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
leesredgt wrote:Very nice man,looks good.This is a general question,but what are the advantages to a v-mount setup as opposed to standard?
most of the time, when a race car uses a v mounted setup it can be for a couple of reasons. some would say it decreases the possibility of any type of debris from impacting the intercooler, while others would say it aids in the cooling factor . i think it has alot to do with less piping equals less lagwhich will give you a much faster spool time.
leesredgt
S14-NEO wrote:most of the time, when a race car uses a v mounted setup it can be for a couple of reasons. some would say it decreases the possibility of any type of debris from impacting the intercooler, while others would say it aids in the cooling factor . i think it has alot to do with less piping equals less lagwhich will give you a much faster spool time.
Gotcha! Thanks!
streeteg
vmounts are far more efficient when done properly, but can actually hurt performance if not properly ducted. It allows air to hit more surface area of both cooling planes, and actually allows the radiator and intercooler to act like a pacman mouth to use all possible cooling air.
Channeling of the air, and usually hood vents above the intercooler help direct the air in to cool then out before getting recycled into heat. Addtionally the shorter pipes allow for faster response due to less volume.
Looks like a good start to me. Make sure you set it up correctly duct wise and it will be killer. Unfortunately with an RB they also make the coolant a PIA to bleed. but eh-- its baller either way
Kalypso
NICE!!!!!!!!!!!!! >_<
copy and past the IMG tags into this thread.
post pics from the front also... I want to see the radiator.
rb26ishere
haha i had to cut my filler neck off and weld it shut for more clearence..... i have to make up a new filler/bleeding neck... i just got the tubing and filler adapter... ill take sume more pics
rb26ishere
i went from bout 3ft of intercooler pipping to bout 10 in lol it should spool alot quicker i hope...
rb26ishere
check out the pic link more pics on there
rb26ishere
umm u want img where? lol sorry dont know how to tag like that
Kalypso
anytime you see a tag that says
[img ]http://whatever.whatever.jpg[/img ]
paste that and pics will appear.
every photobucket pic has that on the bottom of it
Kalypso
WOW!!! and you have pull fans behind the rad!!
f'in smart... for real
rb26ishere
yeh its tite s***ty things is i baught nice fans when i 1st put motor in and then decided to v-mount and those were to thick..... there went 250$ lol
yotik
Car: 240sx Hatch
slick...
rb26ishere
Couple more pics
240z4u
Car: '95 Nissan 240SX
Cool man, nice to see someone around here who isn't scared of real fab work.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
Looking real good. :dblthumb:
Do you have a build thread??? Whats the plans for the rest of the car?
rb26ishere
No I don't have a build thread, should I? Tell u the truth I duno which way I wana go it be nice to set it upin to beable to do anything I feel like that weekend lol can I gota do body work or find a sweet clean shell to transfer this in to. Which wouldnt take long since I didn't modify the body but the upper radi. Support.
rb26ishere
Oh and il get sum more current pics up have since I've powdercoated alot of parts wrinkle black. I setup a spray booth and oven station in my garage so I've been busy
Shocker
Car: 89 240sxHB rb26/30
Loving the build and the fab work! Nice to see someone taking on things like this themselves.
spkrboxx73
Car: 1973 Datsun 240z
Love the air box!!
rb26ishere
Thanks its for sale if interested... I m making one out of all copper going to polish it then clear it. Its gana be exactly like the arc one just copper
chad b.
Car: chocolate chip kouki
+1 for the fab work and thinking outside the box, but to me you're doing something that just isn't necessary. There are guys making over 700whp with no overheating issues with a basic FMIC setup.
More attention to detail on the engine bay. I see a lot of grime and dirt buildup on everything and you're using cheap a** plastic T unions on the vacuum lines. Clean it up and keep it simple.
rb26ishere
Yeh I know I could have went fmic but I wanted sumthing diffrent... didn't want the usual fmic. And yeh that was a cheap plastic fittin to get by temp. Buddy got a lil cut happy when cuttn other stuff. They wil soon be replaced. And every thing is lookn cleaner since I've been powder coating alot of parts latly
rb26ishere
im powder coating the intercooler end tanks and pipping today..
