Tell us about your project!!!!
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
sidewaysvk56z32
Car: 1990 300ZX
im looking to do a vk56 swap in my z32 idk much about it or what all i need can some1 help me out?
Carl H
no offence but if you have no idea where to start then that swap is not for you...do some reading and then go from there.
Raging Bull
Car: Lakester Land Speed Racer
Hi guys,
For some months I've been researching an engine choice to use in my next scratch built race car project which is a Lakester Salt Lakes Racer - also known as a bellytanker.
So I've arrived at a choice between either a vh or vk 41 or 45 (for which I have some questions about these engines I'll post in another thread).
For now, suffice to say the plan for the car is for front engine, front wheel drive with a N/A high revving (9000+) with my own custom made flat slide ITB's, probably (at this stage) WOLF engine management (unless someone convinces me there's a better option at a reasonable price - Motech's too expensive), 8 into one open headers exiting the bodywork out through the side just behind the engine, bigger cams and more compression.
The engine will be backed up by a 2 speed powerglide with no converter, nor a clutch or flywheel (just running straight into the box using modulated oil pressure to gradually engage 1st speed band to get the car rolling as no hard "launching" is required).
That'll do for the engine for the first year - no doubt there'll be plenty to sort out in that lot for the first runs. Hopefully we can run over 200mph in our first runs planned for April 2011.
irax
Car: VQ35DER Powered S14.3
Fullyboosted wrote:I have a 93 chop top S13 Coupe with a VH45DE custom 8.8:1 Compr. Forged pistons and Rods, custom Turbo Headers with Twin GT40 Turbos 4" exhaust etc... my goal 750-800+hp
any pics of this chop top coupe?
imackz
Car: 280zx
Got a 1979 280zx fitted with VH45de motor, Mazworks adapter & z32tt 5 speed manual box, also has Kaaz LSD, IMPUL Custom ECU,remade chassis (heavier gauge steel ,lower & stiffer) koni shockers & custom King Springs,custom exhaust headers & system, converted wheels to ford 5 stud pattern & bigger brakes (care of Hoppers Stoppers)Hope to have engineer cert & on the road soon.Also has custom paint mixed up just for the car, looks real nice.
Turbo.tom
Car: R32 GTR / FD3S / Silvia RS12
I Swap this Summer a VH45 Twinturbo Engine in my R32 GTR.
- 90´R32 Skyline GTR- 92´VH45de with series ECU- 2x RB25det Garrett T3 Turbo´s- RB26dett 5speed Gearbox (with stronger Gearset)- Costum Intake with 8x 720cc or Injetors- Carbonetics Twinplate clutch
Goal is ~ 700NM at 4500rpm with max.12 PSI (100okt fuel + water injetion)
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
Are you going to try and keep it AWD?
Turbo.tom
I will adjust to the RB26 oil sump with the front diff.It will be AWD and AWS.
Geoffs89Pathy
Car: 1989 Nissan Pathfinder, SASed(chopped for parts)
1991 wd21 D44 coilovers, bumpers, lots more..
1995 VH45 into a SASed 1989 nissan pathfinder.
BILLYDEAN
Car: 82 toyota truck with vh45
hello im doing a vh45 swap im my 82 toyota truck i havnt really got started with it yet i have the donnor motor trans ect ect out and reary to go in. i just want to know if anyone has every done the swap in a small pickup before ? al so im havin trouble with the idle the motor idels wired and spudders! didnt do this tell i pulled it out ? the ecu is reading code 14 (ks) from my understading it dnt do much? any ides of what the problem is? thanks
Geoffs89Pathy
a toyota pickup is a lot like a nissan pathfinder which is what i am in the process of putting my vh45 in.
BILLYDEAN
how is it going post some pics
Geoffs89Pathy
. i cut the fire wall out, i am rebuild the front frame rails so they are wider so the engine fits between and i can drop it down more to make it sit level...
i put a Z32 tt clutvh in a Z32 na bell housing and my transmission with the adapter all bolted to the engine. the engine and transmission is sitting in the truck resting on the manifolds on top of the original frame.
just got sone tacking one side of the new frame all up, now i have to do the other side (which is gonna be harder cause i have the steering gear box to clear and i have to tie in the track bar mount some how...
(i did a custom SAS with long arm suspension front and rear last summer)
BILLYDEAN
O WOW THATS INTENSE I DIDINT KNOW IT WOULD BE THAT MUCH LOOKS LIKE IT WILL FIT IN THERE PRETTY ASY JUST STICK OUT THE HOOD
Geoffs89Pathy
are u putting it in that lower rider? you've only got that 22re in there right? yours is 2wd i imagine which itll make it a little easier. but by no means is it simple. not to discourage you from doing it, ithink it would be funny if nothing else to see a yota with a nissan V8
BILLYDEAN
YEAH IN A LOWERED 2WD TRUCK
Geoffs89Pathy
OK FOLKS PICS ARE UP OVER ON NTR. GO CHECK THEM OUT. THERE ARE 2 PAGES. HERE IS THE LINK
http://nissantrailriders.com/forum/view ... 3&start=50
project_hr
Car: Drag racing altered
This is my drag Altered, after doing some surfing, I figure it will be a perfect place for a VH41 or 45 myself....
Uploaded with ImageShack.us
v8altima
Car: 2002 Nissan Altima
I have a 2002 Nissan Altima that I'm converting to RWD. I am using a VK56DE engine. I have my own site for the build www.v8altima.com
I have the whole car gutted out and all ECU wires are removed that run the car with the exception of the BCM unit. I have a custom adapter plate to mount a G37 6spd trans to the VK56DE. The fabrication of the new swap will be starting in a few weeks. I'll keep you all posted as well as on my site.
v8altima
Check out the updates on my build at http://www.v8altima.com
Got the VK56DE sitting in the bay
theramz
Car: 1995 q45
1970 240z
Hey all, noob here. I have a 1970 240z ready for extreme make over. I am buying a '95 Q45 this weekend. My plan is to swap the VH into the Z. I see some of you are working on manual swaps so I am researching to see which 5 or 6 speed to mate up. I will be using the diff from the Q45 also.
Can someone tell me if any of the Z series flywheels will bolt to the Q45 crank? I am a master machinist so I will probably make my own adaptors. Thanks!
Geoffs89Pathy
Z32 na or TT flywheel bolts to the VH45 crank. (1990-96 300 zx)
IThaJ0kaI
Car: 96 G50, 90 S13 hatch
92 coupe, vh with intake, headers, 50 shot of spray. Later down the road I am looking into boost.
brianky84
Car: 1972 datsun 510 coupe
I have a 1972 Datsun 510 coupe. im putting a VH45DE (95) in it. just running it stock for now to see how it works out. its never been done as far as i know. and all the guys on the ratsun forum says it wont fit. i say wait and see. im just haveing trouble finding a fuel management system that will work. but it should be going in this week well a test fit this week to make some mounts and room if needed. ill try to have the shop put up build pics as they go. Oh and im in need of a rear end. if any body has any suggestions let me know. i want a lsd but it has to be pretty narrow to fit under the 510.
sharpie01
Car: R33 AWD DIRT RACER
am making an atempt to build an awd sprint car thingy
we run a short track dirt circuit got 8 clubs aroubd south aussie
but dont hold that against me
stripped the running gear out of gts4 r33 auto built a chassis around it
ditching the rb in favour of a vh41 any info on mateing the auto box to the vh am mid mounting so no dramas with the front diff as its behind it only concern will be front tailsjhaft maybe? but got a few ideas
want to turbo stock vh so any info would be great not wanting gobs of power just enuf not to lunch the motor
anyways cheers
http://s1127.photobucket.com/albums/l625/chukster41/
:chuckle:
XJared
Car: 06 Titan, 83 Z, 10 Z
I'm working on a VK56 into an '83 280ZX. I just posted a build thread in this forum.
New Jersey
Car: 1997 Infiniti Q45
1990 Nissan 300ZX
i have a 1990 300zx na that im putting a 1995 vh45de into
so far i have the car, the vh45de/ecu/harness, and a tt z32 clutch and flywheel along with some maintenance stuff (water pump, front/rear main seal, thermostat, etc)
gonna get a mazworx adapter soon and then bring to a shop to fab motor mounts and get the harness done
dlucke17
Car: 04' Audi A4 Quattro, 06' TBSS, 93 240sx Coupe
What is up guys??? I have a 93 S13 Coupe w/ S15 front conversion that I am putting the vh45 to 6-spd (CD009 out of 08' 350z) swap in... Of course you can find this swap to z32 5-spd all day, but the 6-spd conversion is a little more rare. I am trying my best to stay away from the couple companies that have made the VH45 kits for this swap like Mazworks, etc. so plan on doing most the work myself, (haven't found an adapter plate for my need anyway) Except for the exhaust manifold. I have been following the JZXProject, Q45 - 6spd, but still not clear on the path just yet. I have done a TON of reading up, just know that there are a bunch of little things that I am going to run into with this swap. If I can help you out let me know and any help to me is greatly appreciated!!! dlucke17 @ yahoo.com
chharith
Car: 1986 Toyota Corolla GTS with VH45DE swap.
AE86 with VH45DE Z32 Swap, I'll post up the build write up.
Mr_Sparkle
Car: S14
Slowly putting together all the bits for VH45DE + Z32 -> S14
The S14 is my race car / daily driver at the moment as my truck burnt down.
The VH has ITBs, and A Link Plus ECU, will be getting some Brian Hartley head work (He is in the same town as me)
Pics:
VH45:
S14:
S14 with girls:
http://i12.photobucket.com/albums/a204/ ... CF1395.jpg
Return to “VH45DE / VK45DE / VK56DE Forum”
