180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon May 16, 2005 7:22 am
There's a nut holding the part that has the 3 bolts pokin out of it. You undo that, the spring will make the strut shoot down and you'll be in for a hell of an injury. Undo the top 3 (looks like points of a triangle) and the bottom two at the knuckle. Undo the brake line and the fronts will come off. The rear has two at the top that are inline (the center one is again for the spring thing and will take you out pretty quick). undo the brake line clip and the bolt at the bottom and pull out the strut.
If you do decide you want to undo the center nut that Scott was kind enough to warn against removing, remember to use spring compressors and to have the spring compressors in place with some tension on it. Wear eye protection and gloves before tying to undo this nut if you're on stock springs especially.
