Tell me what wire is what please
1via
I had some smoke coming from the steering column. I decide to take the bottom of the dash board and found that the tape that was holding the wire had melted. The person that wired my fan did not do a good job. So I need to do this myself. I need to know what wire is what.
[IMG][/IMG]
c-rad
Car: 1991 Nissan 240SX w/CA18DET
1via wrote:I had some smoke coming from the steering column. I decide to take the bottom of the dash board and found that the tape that was holding the wire had melted. The person that wired my fan did not do a good job. So I need to do this myself. I need to know what wire is what.
[IMG][/IMG]
Whoa, WTF? The person powered the fan off the ignition harness???? Talk about power draw...
89'ClubK's
Car: 89' Nissan 240SX
Wire it to the battery. Simple.
1via
I want it to run constantly.
c-rad
1via wrote:I want it to run constantly.
That's not a good idea. Puts more load on the alternator which puts causes more parasitic drag on the engine. Just get one of those $30 thermostat fan control kits at Advance Auto Parts.
1via
My fan came with the controller thing. But now My freaking basement door wont open and I cant get to it.
biosehnsucht
Fix the basement door then
I seem to recall someone implied you're not in the US? US models have a thermoswitch you can use to switch the fans on/off (but its set for 198*F on, 188*F off, bit hot for my tastes), you'll want to use that to drive a relay for the fans tho.. maybe a relay per fan (cheap "40 amp" autozone relays can't handle the draw from both my "25 amp combined" fans.. keep blowin the relays, running just one works fine tho)
capwred
i run a e-fan from adavnce auto parts and also use the relay they sell.and it works fine.never had a cooling problem.i did get the 12inch fan not the 12inch that the ka calls for.i also have a koyo radiator.
