Starting imposes high stress on the guides. Replace them before you even turn the engine over again. You've been lucky so far, but don't lose your car's engine by trying to tempt fate one more time. There are no exceptions.kingQong wrote:Yes, I have a '91. She has 108,000 miles. No, chain guides haven't been done (that I know of)
Very true. soo very truemaxnix wrote:Starting imposes high stress on the guides. Replace them before you even turn the engine over again. You've been lucky so far, but don't lose your car's engine by trying to tempt fate one more time. There are no exceptions.
i agreemaxnix wrote:Starting imposes high stress on the guides. Replace them before you even turn the engine over again. You've been lucky so far, but don't lose your car's engine by trying to tempt fate one more time. There are no exceptions.
Highlighting this for future folks with a similar issue. This has been mentioned/discussed severals times, but often gets overlooked. Creates a flooded condition ... keep in mind after it sits long enough that un burned fuel in the combustion chamber leakes down the cylinder walls removing the oil and creating a greater wear condtion on the next strat up ... once the plugs dry enough to fire. Yes, that gas is now diluting your oil. Change it sooner rather than later.kingQong wrote:... I started her up after sitting for a day, moved it out of the lake and shut her right down. ...
