Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Mon May 30, 2005 7:21 am
I wanted the Flex's as well when I first started looking at coilovers. The EDFC was a big factor, but honestly, after you get the KTS set where you like the ride and handling, you really won't mess with the damper settings too much. At least I don't. With my HKS/AGX spring strut combo, I was always adjusting the dampers to try and find a good setting that was sporty and comfortable for the street. I figured coilovers would be the same, hence the want for the EDFC... well once I got the KTS on, the ride was soo freakin good, I didn't have to mess with the damper setting untill I lowered the car a little more. The matched damper to the spring rate really does make a difference. I'll stop rambling, but save the money from the EDFC and get a clutch or LSD or something 10x more useful
