TEIN, who has their products?
BB Turbo
Car: 2007 Nissan Titan KC
1992 Nissan 240SX Coupe
I was wondering if ay you people out there have any Tein products in there car. I wold like to know because i would like to see if any of you all are pleased with them. More importantly, do any of you guys have their EDFC installed? I am interested in that allot. http://www.tein.co.jp
http://www.tein.co.jp/flexdamp2e.html
240_Keyy
Car: '90 240 Fastback
Flex = weak "carpet queen" (thanks Dori Dori) coilover
I have HE's and am very pleased with them, the quality is top notch and they make the car handle like a dream. Not EDFC compatible though.
I would definitely buy Tein again.
burgy240
Car: 2000 Q45 Ann. Edition Blk on Blk
FLex are the same as th HE's exept that they are teflon coated and are compatable with the EDFC. Bothare nice set ups for street and track. Forgot they had different spring rates.....sorry
240_Keyy
Flex coilover spring rates are 5kg/mm front and 4kg/mm rear, HE's are 8kg/mm front and 6kg/mm rear. Flex is definitely not gonna be a good track setup, way too soft. HE's aren't exactly a great street setup because they are too stiff.
If you want them for looks and for the street, get the Flex's, if you want them for performance and track use, get the HE's.
BB Turbo
Wow....thanks for the info, tein is probably who i will go with then.
240_Keyy
no problemo, I like suspension :)
Dori Dori
Car: Cars of course
I had Tein RA's on my WRX. They were very, very nice...full aluminum construction, inverted strut (not for 240's though), threaded shock body, pbm, 45mm piston, 16-way damper adj, perfect fit (had all fittings for brake lines)...the whole shibang! My only beef was that the dampening adjustment was hardly felt unless I REALLY pushed the car and the ride was rough. But that should be expected with any 'race' coilover. Other than that, I had no complaints.:)
Oh, and stay away from the Flex unless you like gadgets and want a 'comfy' coilover.
240_Keyy
thanks for chimin in Dori Dori, did you see that I quoted you up there :)
Holisticbeatz
I'd go with JIC Magic.
voltron
Car: autox, movies, cars!
I have the HEs on my s14. I like them alot, not too stiff for the street ( the girlfriend would disagree ) and they do well autoxing. I think the 16 levels are kinda useless though because I drive around on a setting of 7 clicks from the hardest. That much damper is needed just to control the spring rate for normal street driving. I crank it up for autox. I would buy them againg for the group buy price that I got them at, but I think if I where to buy a new suspension it would be the JICs. Just because I have heard from people who have driven both ( Tein vs. JIC ) that there is a signifigant diffrence in feel.
Dori Dori
Car: Cars of course
240_Keyy wrote:thanks for chimin in Dori Dori, did you see that I quoted you up there :)
Yeah.:D
