Thesil »
https://forums.nicoclub.com/thesil-u792.html
Sun Feb 22, 2004 5:43 am
As some of you may remember, I recently hit a curb 2 weeks ago. Along with bending the lower control arm completely, I bent the tie rod slightly. Rather than just keeping the bent tie rod in place, i decided to upgrade to tein tie rods. I purchased them from Phase2motortrend.com where they were excellent with customer service and had the tie rods out to me to my door quickly and promptly. After the initial install it was apparent that the rods included only the hardware to increase steering wheel angle, but as I wanted the increased angle anyway; I used the spacer included. Immediately when i got back in the car it seemed the whole car changed. (at this point I advanced the timing 20 degrees from a 10 deg retard for a total of a 10 deg advancement.) The steering wheel was overall a lot tighter and more sensitive to the road. With turns the car seemed to predict where i wanted it to go and did it before hand. Turning seems much more tighter than stock and the whole suspension seems a lot more rigid as well.
the tie rods by me get a 9/10, 9/10 because the kit ddin't include the hardware to make the steering wheel angle like stock and only included the hardware for increased angle. Also the kit claims that it can't use stock out tie rod ends, when it seems that the outers are the same type of bushing. All in all a good package for those of whom bent their tie rods in an accident and wish to replace with an upgrade.
