evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Feb 27, 2007 7:26 am
when it comed to coil overs there isn't much to mess up, so long as the spring rates are within a close tolerance of what they are advertised as, and they do have a good customer service department as least the tech portion of customer service, and when you order good shocks (ADS, Penske, Bilsten, Koni Race) you can have them valved to work with whatever spring rate you want to run and are rebuildable, seem the only teins I've seen are on street cars and the owners have no idea of their spring rate they just bought a kit and assume the springs are the correct rate their application, I just hate to see someone go buy an off the shelf kit with no idea what kinda of valving or spring rates their getting, I'ver personally never seen a track ro autocross car running teins, at least not one that was near the top of the raw sort, I know the top finnishers in FP at nats were running ADS with GC's, but I can't afford the ADS
I just hate the mentality that " I have coil overs so my car handles great" the truth is you can put coil overs on your car and make it handle worse, getting the propper valving and spring rate is the difference, my car currently has koni calssic's with ST springs when put this set up on I had to run a fatter rear bar and a skineir frotn bar to ballance the setup, my car consistantly lands in the top 10% raw sort, i just can't seem to keep up with those formula cars and 4 or 5 fendered cars
